Pretty average charger?
Sheriffandy013
12:04 PM
Colorado
Found the build sheet, I know some of you guys are better than others but tell me where I can see what this all means!
Great build sheet for a 68 318 Charger. No rips, tears, or spring damage.
Hard to see the pic's but use this.
Good info, thanks, can you help with the suspension, #62 has a 4 in the box. Also for mouldings, drip or applique marked 5, body belt marked 0 and wheel lip marked 8. It looked like the file you attached may have had more pages than the 5 that hold the answers to these and other mysteries for a new charger owner. Thanks!
That code is 624 = Heavy Duty Suspension With Sway Bar
That code is 535 = Roof Drip Rail Molding
That code is 540 = Belt Line Molding
That code is 548 = Wheel Lip Molding
Those are the pages specifically for Chargers, but this is the site where I got it from which has a TON of info: The 1970 Hamtramck Registry Library Page (1965 - 1969) (hamtramck-historical.com)
Where'd you find the Build Sheet?
Rule #1 of build sheets-
make absolutely sure it's actually for your car.
(Does the VIN match?)
I've found that it's extremely common for a car to get a back seat meant for another car with the same interior option.
Definitely my car but good info!
That's good.
Hamtramckhistorical (mentioned above) is really the best resource.
Just takes some clicking around.
