Ball stud bracket
mobbybege
2:55 AM
reading pa
is this right?
does it line up at the other side (trans/clutch housing) ? if so then yes
It looks really close to what I did. Sorry for the dark photograph but I pulled this from a general drivers side engine compartment picture that was not intended to look at the ball stud bracket. If you look close, I lined the front up with the notch in the framerail. The rear of my bracket may be slightly closer to the framerail edge. Mine lined up without issue when I installed the transmission. I think you are good to go.
