1969 Charger RT Exhaust
Hawk
12:13 AM
AZ
Hello All. Looking for input on acceptable/suitable exhaust for a 69 Charger. TTI is on backorder like most everyone right now. I found a Magnaflow kit but have never used it. Any and all suggestions are welcome. Pics and user experience is a plus. Thank you .
Ecs is dead nuts for stock.. period nobody more correct but it isn’t cheap you get what you pay for. Ecs has it right on the money, gardener and accurate are next in line the comes your kits from summit etc
If Schumacher is still in business, i LOVE my tri y shortie headers ! I can swap a starter in minutes, plenty of clearance for everything, header install & removal is a breeze, and no burned plug wire boots !
100 % agree with Aaron's, I have the same headers with auto trans column shift, full size mopar starter, power steering and napa plug wires. Install was a breeze, never a burnt wire. I did add a thermo wrap on the full size starter, no heat soak.
2 1/2" pipe to the turbo muffs then flow master 2 1/2" tail pipes from Jegs. Fit my 67 just fine.
