Hi Guys,
I have a Comp Cams hydraulic roller cam in my 512. I built it 3 years ago but have yet to get it into my Charger (ended up doing a full resto). I have it on a run in stand and fire it up every couple months. After the last run I decided to check the valve lash so I let it cool down for about 30 mins so I could take the valve covers off without burning my fingers.
When I as adjusting to a half turn of preload, some of the lifters had very little pressure. The springs in the lifters were working but I could push the pushrods into the lifters with the rocker arm although they did spring back.
Is this just a symptom of not running the engine enough or are the lifters garbage?
Worst case scenario, I go for a solid roller cam.
