I'm still working this out. So I was reading and on the Head, by the intake is a spare bolt hole, and I read that this can be used for the battery ground. I was using the front left Intake Bolt, which also holds the return spring bracket. Well, some time ago I did the ol' silicone on the Intake bolts. I removed the grounding cable, cleaned a bare spot on the head, and secured the cable at that location. Cranked the car up and no more 15.0-15.8+ swings, I guess the Silicone was not allowing a solid contact. But I kind of have the reverse, now I'm only showing 12.2-12.4 volts when the car is running--lol. Battery is a Yellow Top fully charged @ 12.6 when the car is off.
