hunterrocks24
Alright guys so here's my question today. I am a newbie when it comes to anything electrical so sorry in advance as I am still learning. I have purchased LED style lights with low, high, DRL, and turn signal in one unit. Below I have copied a link for the wiring diagram.
My plan was to have the lows remain the same 3 prong light, but for the high light its a factory 2 prong light. The new one is a 3 prong so my guess is to take the positive and connect it to the high and low on the light. Therefore when the high switch is activated the whole light will just come on. For the DRL I was thinking of wiring it to the park light but doesn't the park light also flash? If this is the case would I wire the DRL and the Turn signal to the park light?
And the final question. The new lights are rated at 80W@high beam and 60W@low beam. Would my splicing overload the wires via amps/watts causing the wires to heat/melt? I am unsure of the factory gauge as the diagram doesn't have any marking for this.
Thank you in advance for the help!
http://www.retrorarities.com/images/73-74ChargerSchematics.pdf
