Keith Zygowski
New Member
I'm having trouble locating a carb spacer for a 413 wedge motor with a dual plane single 4bbl carb intake. Can someone please tell me where I can locate a one inch phenolic or aluminum spacer. I prefer phenolic. Thanks
What intake do u have? If factory what year and casting number? Kim
Easy enough to get some aviation quality 1" plywood, no voids in it, and trace out the shape n cut one. Wood won't transfer the heat n can be done in the garage on the cheap.Exactly. Most of the spacers referenced above will not fit the factory 413 AFB intake/carb stud spacing. But I'm sure there is something out there.
What carb and manifold are you running? Brand and model?I was mistaken in my earlier statement. It loooks like there are a couple in this Summit link should work. The one Moroso one looks like it might have the correct throttle bore sizes too.
Yes, I'm sorry I should have specified that.I think your question is to the OP.
