My 69 Roadrunner no electrical power
Russ Hood
9:40 PM
TN
Took my car and had the front end aligned this morning. Got to the office afterwards then headed out to lunch. Turned switch - nothing. Headlights or nothing worked. Fuses are good. Starter turns over with screwdriver at starter regulator and starter itself. Alternator was making a racket and I thought that was it. I have checked voltage regulator it's good.
Check the blue fused link at the starter relay. Sometimes they burn out. Also check all of your bulk head connections.
Think more how about a battery cut off installed one in my Wifes expidition saved dead bat lots of times till we figured out it was the windshield leak.
Ok I check some things. Found this under the dash and unplugged it and plugged it back in. Now the car turns over and has lights but won't start. When turning over the ammeter is on the D side but I guess that's normal til it starts.
You've got a loose connection under the dash. Maybe at your ignition switch. Start the wiggle test on the harness as you try to crank.
