FOR SALE 273 Carb 3854S
Road Grabber
11:40 AM
Sarasota Florida/NY State
Feedback: 19 / 0 / 0
This carb ran fantastic on my 1970 Dodge 318 when wanted a four barrel.
Very good condition for a rebuild or restoration for a numbers car.
As pointed out recently, the carb is missing a link the relieve the fast idle.
There is the need for fabrication or a part search.
$500 obo
33D56551-CB21-4AC4-ADCC-5446176F6E68.jpeg 24CDFC84-CBB5-4532-9D63-415388604051.jpeg 447AE69B-F3B8-4764-A61F-8FCB015C182D.jpeg F0B3BCC5-DC6D-43C3-BF5E-4D254E6C3F2D.jpeg 0425D83D-D4F6-4E77-8C85-73F52BC8AA4C.jpeg 6C30EC2E-7BB2-4DF1-8ED2-8038CA9D2815.jpeg
$500 obo
View attachment 1149370 View attachment 1149371 View attachment 1149372 View attachment 1149373 View attachment 1149374 View attachment 1149375
Question: Do you have the connecting link from the choke shaft fitting that connects to the fast idle cam. This link lifts up the fast idle cam when the choke closes. Does the carb still have the 2 spring primary step up pistons? Please advise at your convenience.
BOB RENTON
BOB RENTON
The carb has never been apart. You sound like you are very familiar with the carb. If those piston springs are inside they will still be there.
Looking at the picture you can see I purchased this as a rebuild years ago. There is a stamp on it. There was no reason to pull it apart because the engine ran great as is.
Does it look like in the pic that a link is missing?
I will look at it again and try to get you a more definitive response for you.
I did give it a closer look. You are correct the link is missing. Thank you for pointing that out. Most likely fell off in the move because of those small clips. I looked in the boxes I had but no luck.
I would think it could be fabricated worse case using a choke well rod. They seem like the same diameter. They are tough but are able to bend. They also have the flat portion at least on one side.
I have other carter carbs but they look different.
I will keep looking in the meantime. I have one more spot to look...
Thanks for the update.....yes, the Carter 3854S carb was used on a 1965 235HP/273 Cubic inch Barracuda Formula S model (also Dodge Dart), automatic transmission. The 3853S was used on 4 speed cars. I've used this carb on a 1967 Beleveder II with an LA318 engine and the single plane 273 HP manifold and dual point distributor.....excellent results. 1Wild R/T posted a pix (TKANKS) of the missing link's (pun intended) location. No hurry for the explanation.....I'm just in the contemplating stage........BTW....what's the date code stamped on the left front mounting lug? In addition, some one drilled the mounting flange lugs for additional holes....the origional carb only had 4 mounting holes....not eight.
BOB RENTON
BOB RENTON
Thanks for that intel Bob. I had purchased it 40 years ago? Can't remember about the holes but I'm sure your are correct. I can say I never took it apart and it was a sweet combination for the 318. I believe I discovered that suggestion years ago reading an old Hot Rod magazine article.
BOB RENTON
Back up to the barn... I will look for ya
BOB RENTON
OK Professor - I say that in a respectful manner.... I admire Mopar Intel.....The date code I believe is "F"? what's that mean?
Regarding the date code stamping....a simple alpha numeric code
A = January
B = February
c = March
D = April
E = May
F = June. Etc.
Followed by the year ..... for your carb....it would be a 4 for 1964 or 5 for 1965 . But the build date of the carb or any other similar date coded component would precede the build date of the car that the part was to be installed on, which is part of the the vehicle's VIN code or fender tag or vehicle's Broadcast Sheet. For example F5 would be June of 1965 or similar. Its difficult to see the second character of the date code stamping.
Hope this helps you...
BOB RENTON
A = January
B = February
c = March
D = April
E = May
F = June. Etc.
BOB RENTON
Thank you
I always like to hear Mopar details. Amazes me how some others know about the finer points.
That F is not part of the date code, could have been a rebuilder stamp to keep parts together. The Date code in on the other side with or under the carb number. Hard to make out maybe A6
