Rear Window Trim Holes?
dodge68charger
4:49 AM
Washington
When The Bodywork Was Done Around The Rear Window in My 69 Satellite All The Trim Clip Holes Around The Lower Rear Window Corners And Up The Channel a Bit Were Filled.
Does Anyone Have Pics of The Trim Clip Holes So I Can Drill Them. Thank You
Yup, I can help with that. Give me a day or so to take photos and measurements.
If you look up my posts, I have provided pics and measurements!
So here's the deal...
Starting at the corner (see photo) on either side and then to the next hole:
1st hole 5-7/8"
to 2nd 4-3/4"
to 3rd 8-3/4"
to 4th 8-3/4"
measure the same on the other side and the two middle holes should be 2-3/4" apart (see photo)
All the holes are a tad over 1/2" down from the lip (see photo)
Going up the sides the only hole I have is 18-7/8" up from the corner BUT my quarters were replaced to maybe there is a lower hole that I need to drill. If you have those holes Id appreciate the measurements.
So, if these were filled with weld I would drill off to either side maybe 1/4" or 1/2". Not only will it be a bitch to drill through the weld, it will more than likely just strip the screw when you try to screw into it.
