Help me understand what this is
Jeff Erwin
5:46 PM
Woodinville, WA
1971 Dodge Superbee 440x6. I've owned it about 8 months, now upgrading the dash to add a tach. Not the original engine. MSD red-cap distributor, looks brand new inside. And this thing:
Its a Wells something. On the back:
And no other identifying marks.
The plug looks like this:
Question is: What is it and how can I hook up an original Rally Dash tachometer to it without blowing something up?
The MSD ignition modules seem to have a 'tach out' connection, should I replace this with a MSD ignition box? IMG_6077.JPG IMG_6078.JPG IMG_6079.JPG IMG_6080.JPG
The Wells unit is a electronic ignition module.
You hook up the factory tach wire to the negative post on the coil. Pretty sure all of the ECU's wire the same. Here is a drawing. Most likely the green wire is not used. Didnt see the distributor you were using. Was not scrolled down far enough.
Is that an MSD RTR distributor?
I kinda figured that, more interested in some specs that might tell me what the connector wires are.
Sorry I just read the headlines and looked at the pictures. I didn't read the fine print. :BangHead::BangHead::lol:
Pretty sure this is what I was looking for! Thanks! I had been reading about hooking factory tachs to an electronic ignition system and frying them because of the increased amperage, don't want to do that. This appears to be a factory spec part so the tach should hook to the negative side without creating a mushroom cloud.
Screw the tach
LOL
Let’s see some pictures of the car and more info
Thanx Scott
Becarefull with this diagram, since it shows the ballast bypass being feeded from starter relay. This is true just on lates 70s cars and laters with the specific starter relay for that, but not at least up to 74.
Right on earlier cars that Yellow shown would not be yellow I believe it would be a brown wire. Up to 70 I think. Not sure beyond that.
not just because it shows yellow color, but also is noted like running to the Starter relay provision for that
which it was used since 75 or 76... or something like that LOL
An all years the wire section running up to ballast from ign switch fro the Ign2 stage is brown. Then the wire from ballast up to coil is blue up to 69 and become brown on 70 to make diff over the blue wire running now to the second alt field which is blue.
So to test this tach out of the dash can I just hook up the negative side of the coil and a power source?
You need a ground also
Are you running an factory original 7,000 RPM Tach or one of the Reproduction 8,000 RPM Tachs
Factory Tach where installed / option on the 1971 - 1974 B Bodies
1972-1974 had electronic ignition from the factory so
The bigger question is your MSD Distributor
From what I see it’s just your typical magnetic trigger on / off for an external ignition module
Which is that Wells unit like mentioned , just an aftermarket for the Mopar ECU Ignition Module
You don’t have any extra wires going to your battery ?
Don’t laugh - I have seen guys get pretty good at hiding MSD Ignition Boxes where you can’t tell unless your looking at the extra wiring coming off the battery
Under the battery
On the frame
Under the dash
Then they will keep the factory stuff in place for that factory appearance look
I would assume that’s not the case and you would bee fine running a factory tachometer off the negative side of the coil
What coil are you running and is a ballast resistor in place ?
Under the battery
On the frame
Under the dash
MSD coil and the ballast resistor is in place. The wires from the ignition box actually connect to things, so likely not a fake.
They make a reproduction factory wiring harness for your tachometer
The negative coil wire will run directly thru your bulkhead connector on 1971
Nacho can give you the exact location or number
