maddart
Recently I had a 1967 383 4 bbl rebuilt and I just finished dropping it in and am ready to break in almost.
As I understand it the following procedure is required:
Prime oil pump (Run counterclockwise) Read oil pressure-25-30lbs-standard oil pimp
Bring up #1 to TDC-Line on balancer should also indicate TDC
Place oil intermediate shaft in place-Groove pointing front to back
Rotate crankshaft to 12˚ BTDC
Drop in distributor with rotor facing rear of engine engaged in oil pump shaft, just past #1 cylinder (Counterclockwise)
Connect wires in order 1-8-4-3-6-5-7-2
All wires and plugs in place-Prime carb
Turn over motor and hopefully it starts
What next???
Bring up to 2000rpm and run for 30 minutes correct? (vacuum line connected to distributor ?)
What about timing and carb adjustment? I know timing light and vac gauge required.
What should initial timing be set at and is this with vac line plugged?
Carb is tuned at idle after break in correct?
Inspect for leaks
What next???
Inspect for leaks
