Need a little help with where this wire goes
Builderguy
Builderguy
6720 Cuff Road Jackson, MI 49201
This wire needs a home but I don't know it's address. The brown connector with a black wire feeding it. I really don't want to rip the wrap apart to see where it goes. My wiring diagrams are not much good if I don't have the place it starts or ends. Trying to find it in the middle of the run is a little difficult. As the photos show it is just above the bulkhead connection. IDK may be for a condenser that isn't used on the electronic ignition. One or more of you may know where it goes just by looking at it (no wiring diagram needed). The car is a 73 RR 340 auto with electronic ignition. Little help would be great!!!! Thanks in advance.
Labeled “Brake Test” in the '73 FSM diagrams, it’s the brake warning lamp circuit. Runs over the differential switch in the combination proportioning valve. Grounding it should get you a brake warning lamp with the key on.
On second thought, and after quick inspection, my ’72 RR/GTX currently has one, but that engine harness started as a new H&M reproduction when I restored it, likely is not completely model year accurate. My other original '72 harnesses do not have the test connector. I’m going to say ’73 was likely the first year officially
72 Roadrunner GTX
You are correct Sir. "Brake Test" circuit. The light is on when grounded and key ON. When you know your ****, you know your ****! Thank you!
He does know his ****.
Following up, and with apologies to the OP for going a bit sideways on the thread. I dug out the original engine harness for my May ’72 built RR/GTX, the “brake test” connection is not present. Seeing it again reminds me of another question I don’t recall seeing a discussion about or a definitive answer. What’s with the beige harness wrap on this engine and reverse/NSS switch harness found on this car? Any Ideas? I believe I know but curious about your take on it.
I don't really know. I'm pretty sure I had a 72 SSP w/400 that had a harness like that. This was several years ago. What is your take on it?
This came from "Chrysler Harness Systems"
Please note:
In some harnesses, the original braided covering was 1/2 black cotton and 1/2 gray paper twine. The gray paper twine has been discontinued by the original manufacturer. Until we can find an American source for the gray paper twine or a close looking substitute, we will be covering all harnesses with all black cotton. While not looking original, it will look like a period replacement harness.
Have not seen these, but maybe that is what you have, the gray paper look, IDK
Definitely not a cloth or paper wrapping, it’s a vinyl non-stick harness wrap not unlike the black wrap Chrysler used in that time period on everything, just beige or light brown in color. My first thought is it has something to do with this car originally being a California spec car. There are wiring differences in the engine and transmission harness to support the ’72 California only NOX control system (firewall mounted NOX control unit, speed switch on the transmission, and vacuum advance cut-off solenoid). The extra California only wiring disconnects at the alternator are present as well. Strangely however the other harnesses in the engine compartment, not relating to emissions equipment (forward lighting and A/C), are also wrapped in beige harness wrap. Under dash harness is black as expected.
Another difference I’ve noticed with the original wiring in this original engine compartment is that the composition of almost all the wires and wire insolation is different from standard Chrysler wiring by my experience, finer strands, thicker more pliable insolation, even after all these years. An attempt at more heat resistance maybe?
Recalling now, one of my more recent parts cars, Feb ’72 built Satellite Sebring (400 2bbl) was also a California spec A/C car, pretty sure it had black harness wrap under the hood. More questions than answers now.
Found an E-bay auction that’s been around for while from Brad’s NOS. An NOS brown wrapped engine harness, in his description he can’t identify the application. Says it’s from a ’72 big block, the part number would seem support that until you try to locate it in the manual, the specific number is not there. But, notice it has a “Brake test” connector near the bulkhead connector. From the discussion in this thread, that would suggest ’73 and up. The ’72 California only alternator wiring disconnects is not present in that harness.
Could it be that there were two different supply chains? One for production/assembly plant parts and one for replacement parts. I have noticed that on some NOS parts, they were not the same as production/assembly plant parts. Looks like they were made by two different suppliers. They fit just fine, but have a slightly different appearance.
I thought I had seen that before. I dug through my scrap wire harness pile and found one. This may be the one from the 72 SSP 400.
