PRHeads
- 4:30 AM
- Aug 31, 2018
- So. Burlington Vt
Seems like that would be a subject for a new thread.
T&DAre those T&D rockers, or PRW?
The roller pattern is not centered on the stem. I guess i got lucky here seeing so many having trouble with this. HS will drill the rockers for pushrod oiling if ya like fee of charge.What's not perfect about it?
Sometimes I feel like "anecdotal evidence" and 'Glory Days' is all I'm running on now.Hey Jim,
You make great power with everything you do, but even though you did it without things being perfect in the past, I suspect you wouldn't do it again without making sure it was right. You and I both know why the posted pic isn't perfect, but I wanted to see if the poster knew why it wasn't perfect. Anecdotal evidence isn't a good reason to encourage someone to do the wrong thing. Just trying to make it an educational moment, without beating anybody up, figuratively speaking.
Contrary to popular belief, and much of the information out there, a centered pattern is not good geometry on a roller rocker. That information was originally put out for factory engineered ductile iron rockers, and has been been applied to roller rockers, which is incorrect.The roller pattern is not centered on the stem. I guess i got lucky here seeing so many having trouble with this. HS will drill the rockers for pushrod oiling if ya like fee of charge.
Sounds like an awful lot of work. If you milled the stands off anyway, why not just put a longer valve in the head to get the installed height and forego the lash caps, +.100" retainers, and cut down spring seats or spring pockets?That has to be at least 0.150" increase spring height with the retainer/lock combination for the valve stem to be so close to the top of the retainer.
Both sets of MW Victors, we milled off the rocker stands and used the billet aluminum max wedge type stands so we could control the stand height.
Also used lash caps to increase the rocker to retainer clearance. The valve spring locators we used are only 0.030" thick compared to the standard 0.060" thickness.
It looks like 0.030" was just taken off the bottom of 0.060" locators. PAC provided the 1326 springs, Locators, and retainers for the current set of Hughes CNC ported MW Victors. The old set of heads used PAC 1325 springs and Crower +0.100" retainers with the normal 0.060" spring locators, but the spring pockets were cut a bit deeper. I don't recommend making the spring pockets deeper or you can break through into the Intake port roof.
