Slapstik
I am looking for advice on what to do with my Charger. I am looking to make it all it can be for the street, while maintaining a factory appearance.
The car:
1973 Charger SE Brougham, power windows, A/C, slapstick, F70-14, 80k original miles, 3,963 lbs.
Rear: 8.75" 3.23 open 489 case
Transmission: 727 unmodified
Engine: Late 1972 (original to the car) 400 M code (2v single exhaust)
Rebuilt in 1999 (6,000 miles on rebuild)
Bottom: bored 0.030" new stock replacement pistons, chrome moly rings, high volume oil pump
Crank: Cast, external balance, turned 0.060" (!)
Rods: reused original
Heads: milled slightly, hardened valve seats installed
Cam: Mopar Performance .474 lift 280 duration
Intake: 1973 4 barrel iron, EGR blocked off
Carburetor: Holly 750 vacuum secondaries (have a Thermoquad too)
Ignition: Mopar Performance orange box with high advance distributor, 38 degrees total mechanical advance, vacuum advance plugged
Exhaust: Year One 440 HP manifolds, Accurate Exhaust full dual 2.25" straight through mufflers
The car currently has 6.5" of vacuum at idle in gear, not quite enough for the power brakes, eyes water from the exhaust, had to wire the choke open because it would load up bad with the choke part closed (no pull off adjustment), black soot in exhaust, black soot in carburetor (changed power valve from 65 to 25 & jets from 72 to 71 which created a dead spot off idle so I went the wrong way apparently) fowls out Champion RJ12YC and doesn't want to idle cold, so switched to RJ14YC which fixed those two issues. I believe the cam timing is retarded a good amount causing the low vacuum and loss of the bottom end, but I have not yet confirmed this to be the case. I suspect that while the cam and timing want to give at the top, the stock heads and iron intake aren't up to the task, so it's a dog.
I ran the car at the drag strip and I wonder if it would be useful and entertaining to ask you to guess its time along with giving your advice. Might help determine your credibility a little.
Budget: I don't have a particular budget in mind, I'm more interested in making it all it can be for the street while appearing stock. I want to run the tires and exhaust manifolds I have.
Thanks to all in advance.
The car:
