Looking good so far. You might peruse the section in your book about the number of springs to use with the 5 disc clutch packs. It would be under the performance mods section.
Yes, I will use 12 springs with the 5 clutches and steels. That should work well and be pretty bulletproof (unless the idiot that assembles it screws it up!)Looking good so far. You might peruse the section in your book about the number of springs to use with the 5 disc clutch packs. It would be under the performance mods section.
The steel that you are holding has a burnt look to it, but new steels come with the clutches. It looks like some one has already done some performance upgrades to the BB trans, judging by the 5 clutch discs, missing large spring in the front servo, and elimination of accumulator spring. The number of springs in the front clutch assembly seems to be a personal choice thing. Some people like 6 and others like 15, or anything in between. I like to use 9 or 10, depending on the style of the piston.So last night, I verified my forward drum/ front clutch retainer and also put back together the big block transmission (no pictures of this). The big block transmission will be sold as a core, but I carefully assembled it with all parts so it can be easily rebuilt. In theory, it could be run, but I would strongly suggest to anyone buying it not to do that.
Forward Drum (Front Clutch Retainer)
Here are the clutches and steels from the two forward drums:
So the big block had (unusually) 5 of each.
Here is the spring arrangement from each.
View attachment 1197982 View attachment 1197983
No, I didn't make a mistake. The big block only had 6 springs. A couple of people I have talked to can't figure out why.
Here is a closeup of a steel spacer from the big block. They are kind of a uniform gray, and these may be "Kolene Steel", that has a gray color and is used in high performance applications.
So, I will end up using the big block forward drum with 5 clutches. This is much better than only 3 in the small block!
So now:
I have ordered new front and rear bands, clutches, bushings and even tools to press the bushings in and out. So now I have to wait for those as the transmission will get a full rebuild. As I am able to, I will begin to rebuild my small block with refurbished parts, which (of course) will be posted here.
Thanks for the help and sticking with me!
Hawk
Thanks for the great tips. I will follow those as I begin assembly.The steel that you are holding has a burnt look to it, but new steels come with the clutches. It looks like some one has already done some performance upgrades to the BB trans, judging by the 5 clutch discs, missing large spring in the front servo, and elimination of accumulator spring. The number of springs in the front clutch assembly seems to be a personal choice thing. Some people like 6 and others like 15, or anything in between. I like to use 9 or 10, depending on the style of the piston.
I usually find putting the front clutch assembly back together is the most frustrating part of the whole build. There are wide and narrow styles of piston lip seals, depending on the year of the 727. Some rebuild kits include both styles. If you look carefully inside the lip of the seal, there is a 7 digit part # on it. Match this to the # on the kit seal. Carefully work the seals in place using thin feeler stock, being careful not to nick the seals. I find that using assembly lube rather than just transmission fluid makes this easier. Once the inner seal is started in place, I start tapping the outside edge of the piston down working around its circumferance with the end of my wooden hammer handle, while carefully working the outside lip seal in place with the feeler stock. Are you planning on taking the valve body apart, or just flush it out?
Haha. I'm not sure Tom Hand agrees with me - more like I managed to understand this part enough to agree with Tom Hand!The Tom Hand book agrees with yours as far as it applies to the 2-3 shift and number of springs. It also says that the SUPER heavy duty ( Hemi) transmissions had 12 springs and the Heavy duty( 440 Magnum and 426) had 10 or 9 springs.
So perhaps then I will settle with a 10 springs. I have a 3.8 kick down lever so hopefully that will work well together. My only fear is that with 5 clutches, it might grab faster so maybe more springs will counteract that?I have always used either 9 or 10 springs in my rebuilds, giving a nice crisp shift from 2 to 3. I have used a spacer in the reverse servo to cancel the effect of the spring...
...I use either 4.2 or 3.8 kick down lever. What front servo piston assembly did you use? I really advise against the later "controlled load" assembly because it can affect second gear shift timing...
Yeah, wow, now I need to start better understanding the valve body - the next bit of voodoo magic to comprehend!...I open up the holes in the valve body separator plate per Trans-Go shift kit instructions. I eliminate that small wall in the valve body per Trans-Go and remove the ball from that cavity only. I also set the pressure adjustment and kick down adjustment per the shift kit specs. This is using all factory springs in the valve body...
I think, if I remember my reading, that the lighter governor weights will increase the RPM of that the shift happens? I haven't really studied to understand that part yet.This is using ...the lighter high performance governor weights...
I will PM you about the parts....I have here an A&A Transmission "red spring" later style servo piston assembly, high performance governor weight assembly, and rear servo spacer for $100.00US plus shipping if you are interested. This set-up has always worked for me. This is what I run in my own cars and numerous customer's cars. This is for performance street driving and occasional racing using mostly factory parts. Guys with high horsepower cars and full-on racing may build their transmissions differently.
Thank you. And yes, I am EXTREMELY APPRECIATIVE of the members here who are willing to take the time and answer all my basic (or maybe even convoluted) questions. To all of you: a big THANK YOU!!!Hawk,
As always, knowledge is king. You don't know what you don't know. When members of this forum explain/show what they are doing, it helps everyone. Walking someone through a project is both time consuming (taking pics and such) and intimidating (are members going to strongly criticize my every word). So far, at least from my personal experience, our members are very supportive of anyone bold enough to try.
Keep on doing what you are Hawk, I know that it helps me in my understanding of how things work. And to those members who add input on a build, keep on with this too as there are several ways to accomplish a task. I appreciate all of you as I learn a little more about these cars everyday! What a great forum to be on.
3.8 was what was recommended to me too.I will whole heartedly agree with the 12 spring club. When I built that Trans I used a 5.0 lever. Big no no.went down to the 3.8.. and it worked like it should.
17 years bracket racing that 1 transmission.
