71Beeper
- 3:51 AM
- Nov 28, 2010
- Stoney Creek, Ontario
Here's the link to Nicks Garage video.
			I didn't like the cork gaskets at all. Used the Fel Pro style rubber composition type for decades, no real leakage problems. Make sure the pan bolt holes are not dented from over tightening.
Thanks for the correction. I suck at names of things. I normally look up stuff to verify the names of things but didn't this time. I have gone back and corrected the post so if someone looks at it in the future it will make mores sense to them.Hawk, FYI, that "center servo" is called the accumulator. Those are sealing rings, not bushings.
Are you sure the shift selector seal isn't leaking?I’ll have to read through all these posts. I’m hoping to learn how to stop a 727 from leaking fluid. And to stop fluid from leaking past the pan gasket after installing a new pan and gasket. The old cork gasket leaked so bad, it was like there was no gasket at all..
Just trying to help.Thanks for the correction. I suck at names of things. I normally look up stuff to verify the names of things but didn't this time. I have gone back and corrected the post so if someone looks at it in the future it will make mores sense to them.
Thanks for keeping me honest!
The pan rail has to be F.L.A.T., so much so that a flashlight underneath the pan while sitting on a dead flat surface allows no light to escape. Then, don't over tighten the bolts.
Really good thread with the pics!!Thanks for the correction. I suck at names of things. I normally look up stuff to verify the names of things but didn't this time. I have gone back and corrected the post so if someone looks at it in the future it will make mores sense to them.
Don’t feel bad. There’s a guy from Europe on the Corvette Forum discussing his export 57 Corvette and he keeps referring to the kph speedometer as the “tacho”. So far no one has bothered to correct or challenge him - probably for fear they may actually use that for speedometers over there. But every time he repeats it I sort of cringe. I frequently mangle terms myself.
I like the pan gasket from the A-518 transmission with the steel core and o-ringed bolt holes. They are a little pricey, but are reusable. Up here, I can only buy them at the Dodge store.Yes, I eventually replaced my pan with a new repro one but I think going to the blue rubber gasket was the big difference in stopping pan leaks
That's what threw me. It has a wider, later style bushing in the early type drum. Earlier in this build, I just saw the bushing, so I assumed it was a later model drum. Just today when I saw the hole, something in the back of my head thought that was odd. Somehow my brain pieced together that one detail from the video I had subsequently watched. First of all, I'm glad I checked. But it also shows that knowledge is power - all these videos and stuff on the internet have value!Oh man, Hawk, it looks like you are in a jackpot there! I have never changed the bushings in the sun gears. I have never seen different size oil pump bushings, although I have seen them in different materials. The front drum and oil pump have to be changed in sets. You can not mix and match early and late styles for reasons you have seen. The drum you show is definitely the early style and should have a narrow bushing in it.
I am pretty sure both the oil pump/drum support (I think the guy in the video called it the stator) are the newer style; it is now back in the assembled big block transmission. I looked at all these parts very carefully, and if they were different styles I'm sure I would have noticed (and that is also why I assumed this drum would work OK). However, I will pull the big block tranny back apart and check it to be sure.The oil pump/drum support, I can not tell if it is early or late. Have you switched it, or kept it with the drum? What is the pump in the other trans?
