El.Padrino
What size wire is the smaller red battery+ wire that goes to the post on the starter relay? 1968 B body noA/C big block, auto
Thank you!
Thank you!
The last 2 cables I got had a red #8, but the service manual shows it as being a #10 from the factory.
I would think so.so #10 should be safe
Yeah, that #10 is the wire the op is asking about.I do believe that the brown wire to the starter relay is 10AWG though, but it doesn't handle a lot of current.
You are correct, I missed that. Thanks...Yeah, that #10 is the wire the op is asking about.
I would stick with the 8AWG or 6AWG. A 10AWG wire is spec'd for only 30A, which is why so many ammeter wiring setups burnt up. The wire is too small. I do believe that the brown wire to the starter relay is 10AWG though, but it doesn't handle a lot of current.
Seriously?? He is working on a car for crying out loud, not building the space shuttle or having to deal with building codes. I know what you are talking about, attempting to look smart and all, seeing as how I do have a BSEET after my name if I wanted to look cool and all!!The AMPACITY (amp capacity) of the wire's is determined by the National Electrical Code (NEC) and the use intended, according to the insulation system used (THHN, THWN, XLP, RHW, PTFE, etc) which is determined by the maximum ambient temperature anticipated and whether the wire in in open air or in conduit. When in doubt, it is better to have more ampacity than kess and to use an insulation system that exceeds the maximum ambient temperature anticipated. Since the voltage level is low (12 volts) all of the insulation system noted is 600 volts, select the insulation system that is the most economical....suggest THHN (105° C). IF the ambient temp is exceeded, the wire must be de-rated for amps....the higher the temperature reduce the amps. Suggest reviewing the latest edition of the NEC when in doubt. Just a few additional points to ponder......
BOB RENTON
#10What size wire is the smaller red battery+ wire that goes to the post on the starter relay? 1968 B body noA/C big block, auto
Thank you!
BOB RENTON
Bob is a straight shooter and has helped manySeriously?? He is working on a car for crying out loud, not building the space shuttle or having to deal with building codes. I know what you are talking about, attempting to look smart and all, seeing as how I do have a BSEET after my name if I wanted to look cool and all!!
here solve their issues. He's not very often
incorrect. Seriously.
The small wire to the starter is #14. the large red from the alternator is #10....#10 in a 12v system carries much closer to 60A or more but I limit it to 60....you have to consider it as a total wattage system. The small wire to the solenoid on the starter only runs the solenoid....the large #3 or #4 or #6 (depending on engine), from the battery does all the work.I would stick with the 8AWG or 6AWG. A 10AWG wire is spec'd for only 30A, which is why so many ammeter wiring setups burnt up. The wire is too small. I do believe that the brown wire to the starter relay is 10AWG though, but it doesn't handle a lot of current.
Sorry, but that is incorrect. The red wire to the starter relay "BAT" terminal is 10Awg and the red wire to the starter is 6Awg. The brown wire from the starter relay "Sol" terminal to the starter solenoid is 12awg. The starter relay "I" terminal goes to the ignition switch and is 18Awg. The starter relay "G" terminal is soldered to the relay can for a manual and an automatic has a terminal for a brown wire to the neutral safety switch, also 18Awg. The manual shows the starter solenoid will draw 8-9A @ 6v, which gives approximately 700mOhm for the coil. 12v/0.7= 17.4A and the 12Awg wire is rated at 20A. All of this disregards the resistance of the wire for simplicity. The wire from the battery to the "BAT" terminal on the starter relay has a 12Awg fusible link, so basically, there is no way that wire operates or can even handle 60A...The small wire to the starter is #14. the large red from the alternator is #10....#10 in a 12v system carries much closer to 60A or more but I limit it to 60....you have to consider it as a total wattage system. The small wire to the solenoid on the starter only runs the solenoid....the large #3 or #4 or #6 (depending on engine), from the battery does all the work.
Hey Bob I must say , that was an excellent explanation of the ampacity of wire. I am a retired electrician of 42 years and I probably haven’t heard it explained in that detail since apprentice school. Kudos!
