Jesel front drive
cudatom
2:25 PM
Massillon , Oh
For those that use a jesel front drive distributor and a AR Engineering motor plate. What did did you do to get the plate to fit. By that I mean once gaskets are on the plate it will not fit behind the front drive.
Did you spot race the rear of the plate or space the front drive bracket. Just need about 1/16 more clearance.
No problem with my water pump its fitting the motor plate behind the front drive distributor.
The jesel distributor bracket goes in front of the motor plate
Correct, the AR Engineering plate is too thick.
My options are going to be space out the bracket or mill some off the plate where the bracket hits. Just wanted to see what people did or is best approach.
I'm using the AR motor plate and it fits fine.
Here's a picture of mine
