- 9:41 PM
- Sep 5, 2017
- 6720 Cuff Road Jackson, MI 49201
I have restored a 1973 Roadrunner to as close to original as I can get. I have a second 1973 Roadrunner (340 4-speed Sure grip) that was ordered with a bench seat. Some PO had swapped out the bench for buckets that didn't fit right and were from an earlier Roadrunner.
I hunted down the correct bench seat so I could put the car back to original. I later discovered that I sold the buckets way way way too cheap. Ya don't know what ya don't know and I did not need them, but I digress. I have decided to go with bucket seats on this build since I will making several other modifications (mostly to the suspension and engine) that will take it far from "stock". Heck, may even go with a center console if I can use the existing shifter. I have a set of 1977 Cordoba buckets that really don't look too much different than the 1973 Roadrunner buckets. The mounting brackets are different but I can fab those without too much trouble. My question is, will I be able to just put 1973 RR seat covers over the 1977 Cordoba seat frames. Anyone ever try this or know if it will work?
1973 Roadrunner
1977 Cordoba
1973 Roadrunner
1977 Cordoba
