Locked out
Tang1964
6:42 PM
Nor-cali
Well I was going to try and get the quad cab into my little car port deal. When I locked myself out. The guy I bought it from had taken all the tumblers out to do body work. Any one know how to get in a 64 polara with out a key or tumblers ?
That's weird, on my 67 you can't lock yourself out, thought it would be the same on my 64, but never checked.
If your floor boards are rotted out like a proper 64, you just reach up and pull them out of the ignition lol.
If that's where they are
Yes the inter cylinder and everything is in the trunk
Both are locked. I’m going to probably have to get after it with a coat hanger. Or something shifty.
Reach your finger through the lock hole & poke around, should be a lever that pushes down to release the latch..
So.. Tang 1964, I see the car is a 64 so theres that half, but "Tang" ? The drink? The Sub? Something totally unrelated?
4 Dr sedans going to be a little tough to pry open.
Matilda!! Get me the 6' prybar!!!
should be able to take a butter knife or something of the sort thats dull slide it by the weather strip by the vent window and flip up the latch, I have done it before.
Do your Local Police still carry "slim jims" ? Back in the day, that would work...
Any rust in the floor you could crawl through? :D
I used to have a bent knife to unlock the be breezy study on it you will see the angle you need .
