Those black plastic pins that secure the firewell pad
hunt2elk
7:19 AM
WI
Anybody have a good way to install those flippin' things? I always struggle with them, but eventually they go. Not on my current RR though. Hammer, punch and hammer, silicone spray. No, no, and no. Managed to break 2 already. Fresh paint on the car, so I am not going to drill out the holes. Think by cutting a slot into the shaft that goes through the metal would work and still hold?
I grease them up with silicon lube and popped them with a small plastic mallet while trying to steady them with my other hand - but still had some difficulty. Hard to get a controlled hit with the mallet up under the dash. If the dash is out that would help a lot. But I didn’t learn any real solution or trick for it.
Original ones are much better than the repop ones 2x..... plastic stronger on original ones...I agree with ar67gtx.... some spray lube helps :thumbsup:
I used a "blunt" rod that slid inside the plug and then pushed the whole thing in. Had to be a little careful about not punching a hole right out the backside. Normally slid in just fine. But these are rubber. Maybe I am thinking of the wrong fasteners or ones for a different year. If so, nevermind.
Yes, the 66/67 pins are hard plastic with about 3 barbs on the end
I usually use a blunt pointed punch, but that sometimes too fails, as you've undoubtedly found out. Maybe soak them in hot water first, might soften up the plastic some.
That's what I was thinking. Or maybe a hair dryer.
I warmed them up a little bit with a hair dryer, then put a little bit of grease on them and used a small Phillips screwdriver that fit inside to push them through the firewall.
So are the 69 and 70's. Wish they were the rubber style.
Rubber versions came out about 1972 or 73 time frame
To answer the ops question
I drop them on a pan of hot water to warm them up. then push in with my hand , worked every time
Ended up getting them in by putting a bit of grease on the tip and tapping them with a hammer just to the first ridge. They wouldn't go any farther no matter what I did. Ended up breaking 2 of them by trying to force them. Then I went on the other side and pulled them through the rest of the way with a pair of pliers. Actually went pretty smooth.
