- 1:20 AM
- Jan 29, 2018
- Midland Ontario, Canada
I see that strut bar isn't even tightened up..
Both roll to the frontIs this just one side? Or are both sides like this?
Looking at all the geometry there again, is the torsion bar in? and/or are the LCA's on poly pivot bushings that have slid aft on the shafts with no bar holding them in, as the LCA strut as I noted isn't tightened at the LCA, so I doubt it's tightened at the K frame either. Are the bushings in the K frame?I see that strut bar isn't even tightened up..
Like I've said twice, and the OP has admitted, they aren't even tightened up!I'm leaning towards wrong or improperly installed strut rods
Bushings are in and everything is in place. The degree of the brakes should be ok. Hope there would not be a issue in alignmentLooking at all the geometry there again, is the torsion bar in? and/or are the LCA's on poly pivot bushings that have slid aft on the shafts with no bar holding them in, as the LCA strut as I noted isn't tightened at the LCA, so I doubt it's tightened at the K frame either. Are the bushings in the K frame?
Said strut rod also.Like I've said twice, and the OP has admitted, they aren't even tightened up!
I don't think when they are tightened they would move things that muchLike I've said twice, and the OP has admitted, they aren't even tightened up!
the lower ball joint in post#14 it's not bolted to the lower control arm.I'm wondering if they are the correct backing plates. It might have been a 10" to 11" swap at one time. Could the backing plates go on either side and be on the wrong side?
Also I've seen the A and E bodies with the backing plate nuts on the inside but I thought B bodies had the nuts on the back side of the spindles?
The shiny black makes in look that way.MOHeck guys it looks to me that the lower ball joint isn’t in the lower control arm socket spindle is hanging from the upper A arm. Oh wait I see from the other side it looks to be in the socket I must be blind!
