general questions
ord27
11:11 AM
texas
1970 Superbee with white bucket interior, purple exterior
1)upper interior door color: white? black? body color
I've seen pics of all 3 options. Which color is correct?
2)seat belts: for a big block driver with a mostly very correct interior, do yall run stock seat belts? or upgrade to a 3 point system?
3) seat belt headliner clips and coat hangers: headliner is white, seatbelts black....what color coat clips and headliner belt clips (If I go with original belt style)
thanks
thanks
Just my opinion:
1: Whatever color you want
2: I have a V-Code 70 Roadrunner and installed a driver's side 3 way retractable seat belt and shoulder harness. The factory "shoulder" strap grabs me around the neck, (6' 3" 270#) and the new one is safer and more comfortable.
3: See #2
I'd do: white, stock, white.
factory would be white,on my Bee I have body color
Looks so much better body color. White up there looks very odd.
Interesting. Since I was always used to the factory interior color-match doors, the body color to me appears odd. I only started seeing that, obviously in recent years, on cars that were restored.
yea, I'm still undecided.
The two pics above, also have me debating a buddy seat. Up until now, I wasn't going with one....
The upper door panel color should be coded on your fender tag if you want to go original.
Ive seen them body color or black. Never door panel color. But then again I was not around back in the hay day so I'm not totally sure what is correct. I just like the body color. Breaks up the door a bit.
As said the inside doors were white originally. The seat belts and all retainers & coat hooks were black originally.
Inside doors were not necessarily matching body color from factory. In 1970 you wouldn’t see red, orange, top banana yellow or limelite green, etc on the interior. Since I’ve been at this for years it looks odd to my eye to see that.
Now some exterior colors were used on the upper door frames depending on the color combo: of course EW1 and TX9, also EB7, EF8, FT6, FK5 and so on. But these always matched what was going on with the interior colors. Not contrasting like the hi impact colors do. If you look in a decoding book you can see the list of door frame colors they used.
