TexasRoadRunner68
Considering building a different car. I have a 68 H code car on a frame jig built using the 521 restorations blueprints. 3/16” tubing vs 1/8”, so it was built pretty stout. Has trailer jacks welded on to allow you to level the jig. The car needs most of the panels replaced. 3 of 4 frame rails are solid. The driver side needs replacement or patching. Driver a pillar has some rust, but a donor a pillar is included. Rockers are solid. No fender tag or front clip. Needs the works from AMD. Body numbers match. No rear end. I have the brand new AMD 68 tail panel, an AMD roof skin, the passenger quarter panel, and front driver frame rail. Clear blue Tx title.
Was thinking of asking $8500. Is that reasonable in todays market? I have nearly 2k in new AMD sheet metal along with the frame jig.
