1968 Charger Hellcat Swapped PWM Cooling Fan set up!
Saleh
12:28 AM
Saudi Arabia
Hello everyone,
So this is my first post and I really hope you guys can help me out with my project.
I did a hellcat swap on my 1968 Charger and used the OEM Radiator cooling fan, Also connected PIN #82 to the fan from the ECU but the fan won't work!
Am I missing something here?
Hello everyone,
You mean to the ground side of a relay correct?
The way I see it is that pin #82 energies or operates a relay that switches 12V to operate the fan. The fan also has to be grounded.
power and ground are connected to the fan as well as a pcm signal from pin 82
Hello everyone,
you updated everything in your tune in HPTuners? Similar to below?
This pinout shows PIN 83 is PWM fan control.
What about the possibility the fan doesn't work?
So you're getting the engine hot and it doesn't fire up? The srts started at like 225* F if I'm not mistaken.
I finally figured it out! I moved pin #83 to pin #82 (which was empty in my case) and it finally worked !
I’m about to do the same on my 69 Charger.
Did you end up just using pin #83 to the white wire and power, ground from the fan?
Trying to do the same no luck. Had a friend program fan to work but nothing. Used pin 82 for pwm signal and the I just ran a ground and 12v to fan harness no luck. What do I need to do
