My bad one on right is one from roadrunnerOne on left is from 69 roadrunner Saginaw steering pump other one is from chevy truck Saginaw steering pump
What is the difference View attachment 1244062
Just wondering what the difference isIs the truck one metric? What do they look like where the line threads in. What are you trying to do?
Wondering if there is an advantage to running one or other
I am going to hydroboost brakes and just want to make sure I have adequate pressure with stock pumpWhat are you trying to accomplish? The part you show looks to be the pump's high pressure relief valve - flow control valve. Its specific to the pump volume - pressure capabilities in relation to the steering box volume - pressure needs. IMO....do not arbitrarily interchange them....
BOB RENTON
How did you do thatI restricted my pump flow when connected to a Mustang rack.
If I recall correctly, I brazed the output orifice closed and drilled to a smaller size. I used instructions from Erenberg at Mopar Action Magazine, where I read an article detailing such a procedure. You can probably search and find it.How did you do that
ThanksIf I recall correctly, I brazed the output orifice closed and drilled to a smaller size. I used instructions from Erenberg at Mopar Action Magazine, where I read an article detailing such a procedure. You can probably search and find it.
