Braded throttle pressure cable up grade.
Auggie56
12:10 AM
NW Ohio
1967 B body. 440 with a Demon carburetor and a 727 Transmission. I'm considering buying a Lokar cable, any advice would be appreciated. Any suggestion who to buy from?
There are many out there. With prices ranging from $26 to over $100.
I have used Lokar,Bouchillon,Mancini,Spectre.Bouchillon to me is the nicest set up but most expensive.
Lokar and Mancini are pretty much the same. Spectre,was bought at the local Auto Zone for the $26 and works fine as I have it on my car now.
I take it these are universal cables? I have the factory original brackets and linkages, but have had no luck zinc plating the parts here at home.
Thanks for the input.
universal cables?
727/904 and yes they fit others. This is Mancini's along with their big block throttle cable/kick down bracket.
Are you talking Kick down and throttle cables ? The photo above uses the factory Mopar throttle cable.
