Rchab
Alright I've got a confusing problem going on.
So I went to take my charger out the other weekend and when I fired it up I noticed a loud ticking noise. When it first started it was intermittent, but after a few revs to clear the cobwebs it became constant. Also, it fluctuates with the rpm. I pulled the valve cover and checked to see if a lifter was collapsed by cranking it to close the valves and pressing to see if I could push the lifters but they checked out. So I pulled the intake and got to the cam to see if there was any scoring. I checked this because it sounds more like a sliding metallic noise rather than a ticking or clinking noise. Everything looked fine in there as well. Double checked the lifters and they seemed fine again. Threw it all back together and and torqued the valvetrain again and still have the noise plus what I assume is a vacuum leak but that's a simple fix so I'm not worried about that. Any ideas on what else to check would be greatly appreciated as I am stumped at this point.
