biomedtechguy
Accelerati Rapidus Maximus
- 12:43 PM
- Mar 28, 2014
- South Louisiana
Nice work Mike...
I don't know if its the cam itself or my inability to measure more precisely.
The Cometic head gaskets arrived. Perfect size 4.350" bore on my 4.530" block . Installed the pan studs with some blue locktite. Checked the head gaskets on the block to make sure they didn't intrude into the bore. A little lube on the studs. Hand tight only. Lubing up the studs with ARP before sliding the head on is alot easier and less messy. . I torque stuff different than most. On high torque items I like to start at 30lb/ft. Then go directly to full torque. In this case 70lb/ft. Then when it's completely torqued I crack each fastener losses and retorque at the full torque spec. You wil notice it always takes more wrench movement to reach torque the 2nd time. Valvetrain tomorrow.
View attachment 1247440 View attachment 1247443
