WTB 727 transmission pan of good quality metal.
67charger440
10:57 PM
Waxahachie Tx
Feedback: 1 / 0 / 0
Every pan I’ve tried has leaked regardless of type of gasket used. I’m looking for something that isn’t made out of thin pot metal. Thx. 727 torqueflight
Yes I know I can just buy them, a guy just trying to support the small guy first
try the bold hold threads Your bold hold may be worn and leaking thru the bolt threads Bob Horman
Then something above your transmission pan is leaking
I have a deep cast aluminum pan with the filter extension. What is your offer plus shipping from 70542
I have 30 plus factory 727 pans on the shelf--$30.00 each plus shipping--but have you flatened each bolt hole on your steel pan--I have done hundreds of trans services over the years and never found a pan that didnt need ALL the bolt holes flatened out--Its a major cause of pan leaks if your sure its the pan leaking.Just a few minutes with a hammer on a flat surface like an I beam does the trick EVERY time--Hope this helps
