Vanderstel
I'm confused. The plastic turn signal cancel mechanism seems to be in two pieces, I have a new "top" piece from Classic Industries, see picture.
The lower and top piece seem to be attached with a bushing, see next picture? The whole assembly is loose but the wires aren't long enough to allow me to pull it far enough to get to the wires attached from the back side, or separate the two halves. Do the two halves just pull apart?
The top piece, that I have a replacement for, is broken as you can see in the picture. Do I also need to replace the bottom piece? It seems ok
Second problem, in an attempt to remove the surrounding housing I unscrewed two larger screws, see picture...
Removing the screws did not allow me to remove the housing, when I attempt to replace the screws, there's nothing behind them!
Any help would be appreciated.
