zsn0w
Hi all,
Just wanted to get some thoughts on a stroker build I'm thinking of doing. I'm going to be getting a new Jeep for driving in the winter, and I'm planning on swapping in a 46re and 5.9 magnum from a truck into it. Originally, I was thinking I'd leave it a stock bottom end and just put a cam on it, headers, intake, swap to carb, better heads, etc. I just want low end since it's going into a Jeep that's intended to be used for snowy driving and camping. Won't be going over 4000rpm much at all I wouldn't think.
Started thinking maybe at that point I should just build a stroker? Spend the $1400 on a stroker kit or put one together myself instead of buying a bunch of little things, put a cheap carb intake on there and a 750 CFM carb and be good to go with all the original accessories otherwise. How do you all think this would perform? I know the heads will severely limit it up top, but I really don't care about top end at all for this. Plus later on, if I want to perk it up a bit, I could always add heads. Thoughts?
Thanks,
Zack
Thanks,
Zack
. I wanted a 4 speed anyway, so it doesn't change the plan too much. Plus it's a non A/C car so that's at least one accessory I won't have to worry about. I think if it were a 360 I would probably keep it, but since I need to swap the trans and whole motor anyway, I want to go big block. Plus, there's something that feels right about a 383 in a roadrunner. Especially compared to a 318.
