68 coronet
This is so helpful wild rt and answers a few questions. Also when I look at pics of 68 coronet rt interior I see many have the plain instrument panel like the one I'm looking at. But many have the circle instruments/guages any idea why? Obviously they could come with both? See pic of the car interior I'm looking at attached
Sweep cluster is standard, it is different from the base cluster in that it reads to 150MPH... There are two versions, the early sweep had 10/20/30 & by the time it gets to 1001101220 well you see the problem.... Later sweep reads 1 2 3 4 so when it gets to 100 it says 10 11 12...
Rally Cluster was optional Funny thing on the fender tag it is coded as a 7 under the T which is the exact same as a sweep with a optional Tach.... But the optional Tach is actually much rarer than the Rally Cluster...
Welcome to FBBO from Ontario. Your low serial number would indicate August 1967 build rather than 1968. If you need to answer individual posts, you can start a conversation by clicking on your inbox and replying only to the post you want. Good luck with your project.
On 1968 mopars, the sequence number is stamped on the block and bellhousing just like in your pics. My 68 Road Runner is the same deal. Congrats on the numbers matching engine and tranny!
And welcome to the site!
Actually the block & trans case have the VIN stamped in them... The fender tag, radiator yoke & trunk lip have the SO number...
Rally an option I get it now makes sense so I should be seeing a 150mph on a sweep rt cluster good to know. Great help thankyou
68 R/T kinda is tough to truly authenticate, The VIN is on the dash, the engine & the trans.... But not the fender tag, Radiator yoke or trunk lip... The SO number is on the fender tag, radiator yoke & trunk lip... The only places to truly tie those numbers together are the broadcast sheet or the original window sticker...
The fact the block appears to be original helps allot, the first two digits of the VIN being WS confirms Coronet R/T & the fender tag having WS likewise is Coronet R/T... So chances are everything legit... But without a Broadcast sheet theres no way to prove the fender tag & body belong with the Engine & VIN tag...
End of the day I try not to get to hung up on the numbers... Do you like the car? Does it fit your budget? Buy the car!! Enjoy the car....
Thanks for your Service!!!
Once again great stuff thank you but very sorry im a kiwi and not a service man I only just realized what you ment by thanks for your service. My user name I picked for a local trade site here in nz when I was a teenager. Appoligies if its misleading
Welcome from Illinois whiskeybravo! Sounds like you have some military background? Hope that Coronet turns out to be what you're looking for and you can cut a good deal!
Thanks for the welcome and no military background just a civilian. Will find out soon if car as good as advertised.
What's the so no.?
SO is short for Shipping Order. The '68 Shipping Order (SO) consists of a three character date code and a six digit number. The last six digits of the SO number typically originate with the individual order sheet. Combined, the date and number make a identifier for an individual car used for ordering, invoicing, scheduling and production. It follows the car through the entire process. For the 1968 model year, it, with a little modification already discussed early in the thread, is stamped on the fender tag and body to identify a particular car during production. The SO number is found on the Broadcast sheet, window sticker and other paperwork like dealer invoices. This is what 1 Wild R/T is referring to in his post when he talks about using the Broadcast Sheet or Window sticker to tie the SO to the VIN on a '68.
See what happens when we assume stuff... All Good, We Like Kiwis too.... :thumbsup:...
BTW SO = Shipping Order Number, Also called the VON Vehicle Order Number....
Here's an explanation typed out back in 2014 by none other than 69Coronetrt
Here's a real rough example of how the VON is assigned for non-special order (i.e special paint), package (A12s, Daytonas, Superbirds, etc ) or other specialty VON (Police, taxi, dealer demo, etc) cars for 1968 and later.
December 15th. Regional Zone rep walks into dealership with Christmas tidings for the GM and Sales Manager of the dealership. Drops of a bottle of the owners favorite scotch. "Oh by the way, we've added some new options to the order sheets. Here are your new order pads. Start using them after the first of the year." Hands the order pads to the SM. Each pad has fifty order sheets for a Charger.
January 2nd. SM hands out the pads to salesman Bob. At the top of each pad is a six digit number; aka "the VON". The first sheet of the first pad is numbered 000001, the second is numbered 000002, the third sheet is numbered 000003 and so forth for about 50 sheets to a pad.
January 3rd- Customer comes in to order a new Charger. Bob sits down with sheet 000001 and fills out the order. Turns it in to the Sales Manager.
January 4th- Different customer comes in and orders a Charger exactly the same as the first person. Bob fills out sheet 000002 and gives it to the Sales Manager.
January 5th- Sales manager forwards all order sheets to the regional office. Sheets are sent to Headquarters and routed to plant. These two order sheets wind up at the Hamtramck plant. Orders are sorted internally and scheduled for production. At this point, the only unique identifier to each car for billing and scheduling the car is the VON. The VIN has not been assigned yet.
(alternatively, Bob is told to order some stock for the lot. Bob uses order sheet 000001 and 000002. He's in a hurry, is not creative and orders two cars alike. Turns them in.)
Sally at Hamtramck is in charge of assigning VIN numbers to cars. Sally has a stack of papers on her desk. She knows all the orders are there. Bill comes by and distracts her. The orders get knocked off the desk. She picks up the pile of papers and puts them back together roughly in the same manner but 000002 winds up on top of 000001. Any consecutive order of the order sheets at this point is irrelative. As long as she enters the orders and assigns a VIN, she's good. So car 000002 gets entered and assigned a VIN. She then enters the order for car 000001 and assigns it the next higher VIN. As long as the order was entered and a VIN assigned, she's done her job.
The orders get routed. The cars are built. Since they are going to the same end location, they try to keep the car production together to save on transport costs. So...the cars are built at roughly the same time so they can arrive at the dealership at the same time. They are not built sequentially.
One would expect to find consecutive VONs from the same dealership because the order pads would be numbered sequentially. As pads were disseminated from a regional office in somewhat of a large series, one should also expect to find similar VONs from a certain region.
At a recent car show, I saw a VON on a car. The owner knew the car came from Texas. Four cars down I saw a car with a VON ~200 larger from the first car. I asked the second owner if he knew the history and we ultimately determined his car came from the same region as the first, which is why the VONs were so close together. The dealerships could have been miles apart and received different pads but the VONs on the pads were in close proximity.
Hope this makes sense.
Oh, and since you asked about pictures of Doug's Coronet R/T you get a picture of my Coronet R/T.... Shameless Self Promotion.... :lol:
Gold wild rt. I've learnt more in the last 12hrs than I have in the last 4 years. I've always loved reading posts but asking questions certainly trumps.
By the way nice machine I can't get enough of these coronets.
I flew to the north island this arvo and bought my coronet Thanks so much for the help and amazing info. Had to fly home unfortunately as no room on any ferries between the islands but will fly back and drive it home in a fortnight.
Thanks so much for the expertise. I'm now a proud coronet owner. We don't see many in nz so very exciting just to see it. Lovely owner to. Deal done on a hand shake and he told me I could drive it away even though the funds wont show up in his bank till Monday. What a sweet dude. Unfortunately I couldn't get it home today but will soon
Now the real fun begins. Welcome to the site.
