451Mopar
I mentioned the Lunati 10230703LK Voodoo because it is 3-bolt, and should be easier to get. The cam @ lifter kit is only $250.
Lunati and Summit list it out of stock, But Jegs says ships today?
https://www.jegs.com/i/Lunati/638/10230703LK/10002/-1
With the adjustable rockers could go with a solid cam also?
The Hughes cam would have more lift, but 3-bolt is special order, so it is sort of like having to special order a cam from comp? Just thinking of lead times and cost?
The smaller cam should give a big torque boost from idle to peak torque, but will fall off pretty quick after that. The heads still flow good (310 cfm) at 0.500" lift, so peak power might be decent too. I could compare the cams in Dynomation 6, but without knowing all the port lengths and cross section areas it won't be all that accurate? When I ran the iterator for max torque from idle to 5,000 RPM with the current setup, it came back with a cams around 220 on a real narrow LSA?
I could iterate the combination from 2,000 to 6,000 and it would likely show a slightly larger cam.
the iterator allows for Peak HP, Peak Torque, max HP under a RPM curve, and Max Torque under a RPM curve.
