First of all unless the arm is really screwed up it will change nothing by bending it. With the unit out, wire hooked up and a good ground you should be able to operate the sender and see the gauge move its full sweep. Try that before bending anything. My bets are it still will not go to full.When adjusting the arm I should bend the tab in the top of the sender for a higher reading on the gauge is that right
