WTB 71-72 Steering Column Main Shaft
dodgefox5
6:08 PM
Cleveland, OH
Feedback: 1 / 0 / 0
Looking for a steering column main shaft for my 72 RR. My column currently has what I believe to be a Cordoba shaft with a rag joint in it and I am moving over to rack and pinion and would like to delete the rag joint. Shaft is to short to just cut it off and weld the u-joint onto unfortunately. I looked around and could only find freshly rebuilt ones and I really don't need one with a rebuilt steering coupler as I won't be using it. Just need a column main shaft.
Thanks!
Yeah no problem. I will get the length of my current one and the diameter tonight when I get home.
Thanks!
I have 3 different ones.
42, 39 & 35"
The one currently in my car is 42" and the diameter is around an inch coming out of the column bearing. It also has a hole punched in it towards the top for the wheel lock pin. Just let me know. If you do happen to have the right one go ahead and PM me.
Thanks! I really appreciate your help.
