ksurfer2
For additional info, here is the cam card.
Another move in the right direction on Thursday night. I went 10.937 twice. That would have been a new best, but my last run of the night was even better. A couple of upgrades since the last passes. I removed the mechanical water pump and replaced it with a Mezierre electric pump (I really like how quick the car cools down between runs now). I also changed the accelarator pump nozzles from 33's to 45's.
RT. .012
60' 1.489
330 4.393
1/8. 6.879
mph 98.47
1000 9.048
1/4. 10.905
mph. 121.11
I can't see whats holding it back after all these posts.
I think it may be pretty close to it's potential. I do still think there is some left in it due mostly to my inexperience. My short(ish) term goal is to run the 10.50 index. A cam swap will be coming within the next couple of months and while it is torn down for that, Maybe some head work as well. I hope that will get me where I want to be. Long term....a total teardown, and build for the 10.00 index. The cross ram will stay. That will need to by pried from my cold dead hands!You've already picked up quite a bit with your same basic engine combo. I do not think where is much more left without engine changes. For someone to say it should be quicker ? But what is the valve job like? Port prep? Is it actually 10.5-1? Or is that a perceived number? Where is the cam actually installed? You are now at a crossroads. Run it as is. Or hop the motor up. How much? My bet is a 440-25 Indy intake, more compression, bigger cam, and some good port/valve job work would put it in the 9's.
It certainly looks like it needs more compression as a starter.
Didn’t you dyno test one?I loved my cross ram. But to make 9 second power with one isn't easy.
I "get" that, and for now, feel the same way about my 6bbl carbs, but the Indy ModMan CNCd to MW port size for the TF 270s is the starting point for my 572. If I ever wanted more carb, I'd be looking at the Indy 440-25 or a cross ram, just for the "cool" factor when the hood is open, and that is how I use my car more than best track times. Besides, the size of the engine at 572 has got to make up for some other "compromises".The cross ram will stay. That will need to by pried from my cold dead hands!
I agree.
Or..... at least more(way more) cranking compression.
I tested a 499 that had one, with ported 440-1’s and a basic bracket race roller cam. I don’t recall the CR, but it had flat top pistons.
Untouched intake manifold...... made 642tq/671hp.
3650-ish pound car.... was running mid-10’s as I recall.
Edit- after doing some digging...... It appears the car that 499 went in ran 10.30’s@ around 130 with the stock cross ram on it.
Little EZ 295Good numbers.
Stock x-ram? Yes
What’s the cam? Comp roller R1 from Indy 272/276 .620
Heads?
