1966satellite
- 11:49 PM
- Dec 2, 2011
- Germantown Hills, Illinois
What should the bolts holding the case halves of a cone type sure grip be torqued to?
Thanks! 30 seems about right for that size bolt.I think it is 30 ft lbs.
Dry torque for 3/8" is 40 but reduce that for 'wet' or lubed by 40%. I use red loc-tite and go with 35 lbs. Inspect the bolts for stretch if you think someone has been in it before. Heck, doesn't hurt to inspect them anyways. Never know what the tech was doing at the factory when it was assembled.
Doesn't red Loc-tite need the threads to be dry for it to be effective?Perhaps, you should CONSIDER replacing the bolts with hardware by ARP, assembled wet torqued to the ARP specs, using Red Loctite as as suggested. Good insursnce....
BOB RENTON
I thought that Loctite products are anaerobic that cure without the presence of air? Perhaps you are correct....Doesn't red Loc-tite need the threads to be dry for it to be effective?
