PRHeads
- 11:06 AM
- Aug 31, 2018
- So. Burlington Vt
I've read about this "mystical" swap, but I sure would like a detailed explanation of the benefit(s) and the process (is it just swapping plug wires on the cap?)4/7 firing order swap
Also, would this swap be something that a cam designer should or must be made aware of?
Mine is a 4/7 swap. Just have to remember the new firing order.I had the same question for the tech, the swap is as simple as moving the plug wires on the distributor cap.
I can't WAIT to see how that works out!I completed the swap of the factory style cross ram to an Indy 440-25 (keeping the same dual eddy 750's on top)
My old 498 with box stock -1's, 270/.650 cam, made 650@5750 with a stage 1 63 crossram. It made 710@6750 the same day, same carbs with a 440-25. Never even made a jet change. So there was probably more in it. Started the pull at 4000. It was better from 4000-6750 everywhere, lost nothing at any rpm level.The story goes: Indy 440-25 is 90 - 100 HP increase over factory crossram. We'll see........
I would think that would depend a lot on car weight. 50 hp won't help a 4400 lb car as much as it would a 2400 lb car. I'm sure your car can put every one of them to good use.I haven’t raced any dyno’s, so curious what ET difference will be.
