biomedtechguy
Accelerati Rapidus Maximus
- 10:35 PM
- Mar 28, 2014
- South Louisiana
I know a number of forum members have dual disc clutch and pressure plate setups. Because of the heat that slipping a clutch hard, at the launch, using a HitMaster launch/clutch controller, McLeod recommended the RXT model, which I have broken in and have no problems with. The material makes it a bit "grabby" in that it's not as smooth as an organic disc, but I'd roast an organic clutch and the smell of burning hair isn't pleasant. The 572 RB is going to be in front of it once it's done, but for now, my 440 6bbl will provide the power.
So I let the 440 6bbl wind out to 6k every time I'm WFO, not "forced", but it wants to. Rev limiter set at 6,200.
Anyway, I'm asking this question because I haven't had ANY problems shifting at 6k RPMs, but someone with a lot of manual transmission experience said that "dual disc clutch systems don't shift that well over 5,500 RPMs."
I know that over 5,500 RPMs isn't a common territory for many big blocks, but if any of you have a dual disc clutch system and shift 6k RPMs or higher, please share your experience.
Thanks.
Thanks.
Progression Ignition
system that literally is a concept in action that I've always dreamed us "carb guys" could have is the next step for me, and I am going to use it in my 440 6bbl, but I am extra enthusiastic about it's work it will do in my 572. Of course, it has a rev limiter. I may need an outboard 2 step, to be able to mat the gas at the starting line w/out overrevving my engine, but I have to discuss that with Progression, that's one question I don't think I've asked them yet.
