Hard Brake Line Connector Colors
archangel
9:37 PM
Washington
I am replacing the original hard brake lines on my '70 Super Bee. I ordered a set from Inline Tube. When I received them I was surprised to see that the connectors/fittings were color coded. Is that factory correct?
I reached out to Inline Tube who confirmed that it is. I am just looking for a second opinion before I install them.
I do not seeing anything about color coding in my MMC (Dave Wise) manual but it is a big manual so maybe it's there somewhere. I also do not see any color on the few original lines that I have already removed. Of course maybe the coloring worn off over time.
Oh, not that it matters but I have drum brakes all of the way around.
'69, but ya...
As luck would have it MMC just replied to my email query from a few days ago. To their knowledge Mopar did not color code the actual connectors/fittings.
dadsbee, so those are factory original lines going to the master cylinder?
I believe colored fittings are correct. The attached pictures are from my first 'Bird, back in the mid 90's. I purchased the lines as reproduction factory originals. The front fitting is blue, it appears, and the rear was purple. This is a 1970 with power discs in front, drums in the rear.
I have never seen colored fittings on brake lines, and I have been playing with old Mopars since I got my first 63 Plymouth in 1972. I have worked on, and scrapped, a bunch of them over the years.
My '67 factory fittings have no color coding. Took off originally master cylinder when I changed to front disc's. That was the 1st time a wrench had ever been on the fittings.
Thank you everyone for your input and pictures. I am striving for as factory correct as practical so I think I will investigate the feasibility of stripping off the coloring before installing.
I have to admit that the coloring is sort of cool looking. If I were doing a resto mod or just fixing a daily driver I would be inclined to leave it as is especially since practically speaking the only fittings that are readily visible are at the master cylinder.
