440 stamp pad
63SplitWindow
11:43 AM
Montgomery County PA
Looking for some help with the numbers on this stamp pad. They are:
G440
F 7114
19
I know the G440 means 71 casting but I can't make sense of the rest.
Here is pic
Looks like a rebuilders stamping.
If you look super close , might be able to see more #s with the same font as the G440.
First time I've seen a flat head screw holding a valley tin with no reinforcement bar
Motor is on a stand and not fully assembled.....cover just on to keep out dirt until rebuild
What # is to the left of the 19 ? Looks like a 5 but can't quite tell. If it is the motor was built May 19
Wow, you have good peeps......I did not see that until I hit with wire brush......yes....It is a 5.
And there is also a "C" in the lower right corner of the pad that came up under the wheel.
Some moron stamped the job number at the machine shop that did work to it (F7114). This is why I use a sharpie for initials. A little carb cleaner and it is clean...
Not sure what the "C" in the right lower corner is.
If there was an "LC" stamped there it means - Low Compression
Maybe somebody else could help to identify that.
Looks like a 5 to the left of the 19. 5/19 build date.
mine reads f440 left side and hp bottom right, anyone care to decipher this
