- 2:39 AM
- Nov 21, 2008
- In GTXtacy Illinois
I'd say it worked! Im a believer!
Before
After
Before
After
Mario - join the SPI forum and poke around in the archives. Everyone over there is pretty knowledgeable and you can even call Barry up (the owner) and ask him yourself about aluminum. Hand sanding is best as a da can polish the metal as the paper wears out, negating the desired effect of giving it tooth.Paint question...
Looking to repaint Reba inside and out.
1) do I need to take it down to bare aluminum?
2) I assume there is a special paint / primer to stick to said aluminum?
@eldubb440 @5wndwcpe
Very nice....like brand new.
Very nice....like brand new.![]()
I would, Mario. Looks great!Im wondering if I should spray the hitch with a clear coat of some sort so it doesn't flash rust?
Dang when your done that boat and trailer is going to look brand new.![]()
IMHO, I would take it down only as far as required....to solid primer - whereby nothing is flaking off, or any deep edges. If the original primer is feathering out OK, I would run with that. Check first to make sure that your new paint will not 'fry' on the old surface....if it doesn't - you're good to go.A couple of cringe-worthy questions for the group...and they both involve aerosol cans View attachment 1304713
I am using 1k self-etching primer in an aerosol. Do I take it all the way down to bare aluminum? Can I sand the current paint down enough to where the primer will stick? I am painting over the primer with automotive-grade paint (in an aerosol) and then a 2k urethane gloss clearcoat (yes, that damn aerosol again lol) over the color.
It's not chalky. Im thinking if I hit it with a DA and 400 grit, the substrate should be pretty flat. Also, the 1k primer is a filler/primer. They called it a 'wash primer.' So that'll help. lol
The gray is the bare aluminum of the boat. The other side is a little bit better. What say ye?
View attachment 1304719View attachment 1304720View attachment 1304721
That is called an 'Anchor Mate'. The anchor is supposed sit under the hood. It has a rope and pulley system along the port side all the way back to the helm.
Of courseIMHO, I would take it down only as far as required....to solid primer - whereby nothing is flaking off, or any deep edges. If the original primer is feathering out OK, I would run with that. Check first to make sure that your new paint will not 'fry' on the old surface....if it doesn't - you're good to go.
My opinion only of course. I have done a ton of painting, but I am far short of being an expert.![]()
