Big block into small block chassis differences?
Takoctopus
1:39 AM
Plainfield, Indiana
So I have a rusted out big block car and a solid small block car I want to drop the big block parts in. So far the only thing I really notice is the passenger side engine bay sheet metal is different. Does anyone know if there is anything else I need to remove sheet metal wise to install in the small block car besides the passenger engine bay wheel well? Both 74 RR, Thanks for any ideas
Are you referring to the radiator support opening ?
The passenger side on the engine bay has a huge hole to clear a big block where as the small block has a much smaller hole and cover. Primer car is the small block, blue is the big block car.
The radiator support looks to be the same size, wondering if there is anything else
The K members are different
Small Block K member can be used with schumacher motor mounts. I personally would use the Big Block K member with stock mounts.
Someone hacked a hole in the inner fender of the blue car. There are no differences between the inner fenders of a big and small block car.
73 and 74 Big Block B Bodies had a large access hole in the passenger side inner fender from the factory and used a rubber splash shield to cover it.
Here's a picture of my 73 RR GTX as you can see the passenger side access hole from the wheel well looking towards the engine.
Thanks for the info on the K member, mine is rusted out on the rear mounts so this will come in handy when I shop for one
Well,
you have Two K members to make one. Just a suggestion, you could remove the mounts from the rusted Big Block K member and replace on the Small Block K member.
Torsion bars are also different.
And sway bar, but that's not excessively critical. No mod needed but a replacement. The only problem on this is the lack of options from shops if wishing new parts.
They made a LOT of 400 powered Cordobas.
.....but did anyone save the parts?
Everything is coming out of the big block car and going to the small block car, already have the passenger side wheel well pulled to weld into the small block car. The knowledge here is pretty good. It’s helps to have people to bounce ideas off of.
Why not just make a pattern and cut up the small block inners or just not cut or replace them at all?
Just have to change over the one side, I have seen people put big block in small block cars but it get tight. I could just cut up the small block car but it’s cleaner to remove the spot welds and weld it back in.
