SOLD 1966 Plymouth Hemi Belvedere 1
68blackbee
1:22 AM
new jersey
1966 Hemi Belvedere 1 project car..original 426 hemi,4 speed car. one of 57 built. ex drag car, never tubbed or caged,No motor(blown up years ago),has original,radiator,4 speed and dana 60. has vin tag, fender tag, build sheet and warranty card.body numbers match..One owner car..K frame was changed at some point. has rust in front floors and Ds framerail but easy fix. has seats but needs to be recovered. have grille,nos side moldings for it. Needs full restoration or make a cool patina hot rod. 15K obo. located in NJ.
PS. if it doesn't sell i would be looking for a 66 Hemi engine and parts to rebuild this rare beast!
frame rail and floor rust has been repaired. looking at a 66 hemi for it. might just keep it and make it drivable.
purchased a bunch of parts for it, Hood,rs fender and door,trunklid,grille,bezels,bumpers,original wheels. price is now 16K..
Also, located a complete 426 hemi air cleaner to oil pan available for 17K.
Can you post pictures of the Hemi and what year did it come out of? Is it running?
somebody had a vision! my 66 had the rear wells cut like that with L60-15"s and the stance set with just enough clearance so no scrubbing,car looked great and hooked good enough to pull the front wheels in second with 3.91's in the dana. and 90/10 shocks on the front!
1967 motor,it is not currently running heads are off for inspection. I plan on assembling and get running on my engine stand.
just acquired a correct hemi k frame.price adjustment 17K as a roller..I now have everything to assemble car but a driveshaft.I Disassembled the 426 hemi engine to inspect it..looks very clean inside appears to be rebuilt,good cylinders, standard bore, standard crank..stock compression pistons, racer brown camshaft. Will inspect heads, cleanup and reassemble..Disassmbled original 4 spd trans and looks very nice inside..gummed up from sitting, cleaned it up, resealed and assembled. ready to go.
