To remove rear main seal with crank in. Don't me how it works.
What is supposed to do/solve? Curious.
I think you use to pull the upper part of the old seal out, then pull the new one in...with motor still in the carWhat is supposed to do/solve? Curious.
Yup had to lube the snot out of the seal cause it was still a booger to pul thru. But a good rope install was leak free for a long time done right.That’s a sneaky Pete seal install tool. Once you remove the old seal you sneak the cable around and up behind the crank in the seal groove. Then small gripper clip grabs the new seal and you pull the seal in.
I agree, great video. But the million dollar question is did it stop the leak?
Awesome, when does it go into the car?
What kind of vacuum at idle and what springs are in the carbs?Once I get the fuel distribution sorted I plan to go through the gearbox and then into the car it goes. It’s going to take some time for me to get the jetting sorted out on these carbs. I tried bigger metering rods but still rich at idle and it was the leanest calibration on the tuning chart.
From here on I will be trying different jet and rod combinations to work out the rich idle condition this is a learning experience for me as I’ve never dealt with dual 4 barrels on anything. It’s running pig rich and I’m getting gas in the oil and changing brand new oil every time I run it will get really expensive quick.
Anytime I've had a rear main seal leak a Felpro and good sealer on the retainer sides fixed it. I think the retainer sides are generally the root cause.
Hi Beekeeper,...The best instructional video I've seen on this leak problem with really clear illuminated views on the specific fitment problem areas & expertly done.....Hope all your motors run drip free....Hope things are good in Eastern Tn as I go thru through town to visit my son on Clinch Mt Ridge, near Spruce Pine Church..... Maybe we can meet up sometime.I know this subject has been beat to death and yes I have read all the recent threads on here and moparts and dodgecharger about the different ways to fix this and the opinions on what works. I would like to do this one time and be done with it so the question is should I go with a rope seal with factory retainer or try the rubber seal using the directions Hughes engines has? The crank is an older eagle with the grooves to direct the oil back in the engine. The current set up is a rubber seal with a billet retainer not sure who made the retainer. Also have seen the one piece seal from fast fish but don’t have any experience with it.
Engine is a 426 hemi
Shoot yea maybe we could meet up sometime. My taxidermist lives on Spruce PineHi Beekeeper,...The best instructional video I've seen on this leak problem with really clear illuminated views on the specific fitment problem areas & expertly done.....Hope all your motors run drip free....Hope things are good in Eastern Tn as I go thru through town to visit my son on Clinch Mt Ridge, near Spruce Pine Church..... Maybe we can meet up sometime.
I just put that in my boys 4.3 engine and holy smokes did it stop his rear main seal leak. I’m seriously thinking about just putting a rope seal in mine and add the blue devil to it on its first run. This stuff has made a believer out of me and his truck leaked worse than my car did.Please note - I understand that oil stop leaks have a snake oil reputation. And in full disclosure I have not had the nerve to try this stuff yet - but I do have a couple bottles sitting on my shelf. I have a 66 Corvette and frequent the Corvette Forums and there have been many, many positive reports coming in from even usually skeptical members and mechanics, about this BlueDevil product really working at drying up oil leaks without any evil consequences. My 66 Hemi is dripping everywhere and it’s going to be awhile before I can get to replacing gaskets, so I’m planning to put this in it shortly in hope of slowing down some of the leaks in the meantime.
So, not advocating but just throwing it out there for thought.
Amazon product ASIN B000OAEN7C
Years ago I had a well worn 79 Dodge 1 ton and it put down a spot of oil that was about 4" in diameter every time I shut it off. Even the clutch was oil soaked so in went a bottle of stop leak. Don't remember the brand but after leaving it in there for about 200 miles I changed the oil when the leak was about the size of a dime. I would imagine the engine still had the original rope seal in it. I haven't had good luck with lip seals either but I know the rope seals worked well.I just put that in my boys 4.3 engine and holy smokes did it stop his rear main seal leak. I’m seriously thinking about just putting a rope seal in mine and add the blue devil to it on its first run. This stuff has made a believer out of me and his truck leaked worse than my car did.
Do you clock your seals? Again, my engine builder guaranteed mine wouldn’t leak. Factory retainer, felcro black rubber seal, he claimed it didn’t need clocked if done correct. He did use the side seal but I couldn’t tell where it was leaking because everything was wet. He swore on the Bible it wasn’t leaking at the block seal but that’s exactly where it was leaking at. Can you clock the seal at 12 and 6 o’clock and press the retainer on the seal itself? Had a guy tell me that’s way he done them and he never uses a side seal.We use the factory retainers, stock neoprene seals in the Kits..... never an issue.
We 'hang' every BB Mopar engine we assemble here with just the Crank/Seal installed and completely submerged in Oil for a few hours before proceeding with the rest of the assembly.
If it's gonna leak ?.... we want to know BEFORE we run it on the Dyno !
Forget the side seals, we use the side to side 'play' in the retainer and move/drag the seal half side that doesn't seal against the crank over into contact(BB Mopars are notorious for that).... then tighten the Bolts and just silicon the sides up.
Again here...
Factory retainers, stock seals.... never an issue.
