I replaced mine yesterdayday. A 3/16” punch and mallet moved the upper seal around to where I could grab it with pliers and rotate it the rest away around to remove. I lubed the new one with Silglide and was able to push it in by hand without much issue. Offset it about 1/4”.
I used a bit of Super Glue to secure the neoprene (?) side seals to the retainer in place, some Loctite 528 on the end of the crank seal, and a thin smear of the Right Stuff on the retainer mating surface. I set the retainer in, pressing the side seals in with my fingers as it went in and snugged the bolt down but saw the side seals were just slightly proud of the pan surface (maybe 1/64” or less) and worried they had slipped a little so I pulled it back out. The seals were still flush at the upper end so I wiped the side seal lightly with the Sliglide and reinstalled - same result so called it good, torqued bolts down and filled the bolt recesses with RTV.
I haven’t done anything on the backside of the retainer side seals. Clearance to get in there is tight with the flywheel in. I may see today if I think I can ge a sealant tube up there high enough to lay a bead and smooth it with a pop cycle stick.
Then I’ll see what happens - either a hero or a goat.
