Road Grabber
- 6:34 PM
- Apr 14, 2020
- Sarasota Florida/NY State
If they are 2 piece rotors like your pictures they will be 1970-72 spindles.
The painted black rotor in the photo is a two piece?
If so do you know if I can get replacement rotors?
Can 1970-72 spindles that receive 11” rotors bolt on different caliper brackets to place the larger correct 11-3/4 rotors?
Just looking at all options if I keep these spindles on the cars. My biggest concern is to be able to replace a rotor that is too thin if I need to. The existing setup does stop the car fine but I don’t want to keep it if I can’t get replacement rotors.
If I can bolt on a different caliper bracket to enable larger rotors like the service manual says then I would do that.
I will have to look into the spindle swap for the “hot setup”. Is it something easy to locate? Can be outright purchased? Etc because the spindles are off the car on the road runner and now would be the time to do an upgrade. I don’t want to swap spindles and risk damaging ball joints/boots to do it later.
Thank you for the help
