906 factory flow rate?
68Satellite440
1:25 PM
Marlow,OK
Afternoon guys,
I’m needing some feedback or results if anyone has flowed some factory non-ported 906 heads. Im needing the CFM flow results for doing some math equations for camshaft compatibility. Ive seen a couple guesstimates at 210-230cfm. But im hoping someone has the actual results.
The engine is ‘68 440hp block with factory 906 heads and factory intake with 600cfm carb and new long tube headers.
Lefty tree'd me. Stan Weiss's site was what I was gonna recommend.......
A big part of flow on stock heads is the quality of the valve job. I've heard of bad valve job heads at under 200. I think 230 is high side of stock, with a good valve job.
I learned of it from you, kudos to you. Since then, I've found myself lost for hours there! :thumbsup: :thumbsup:
The link doesn't seem to be working? Interested in the numbers
